Level/Lift Advice: Bilstein 5100's v. ProComp Pro Runner's
wheelersoffroad.com has all 4 for $365
I will be doing the 1.75" setting up front, a cornfed 1" rear spacer and some 275 BFG ATs:high5:
According to the Bilstein USA website for a 2012 TE the fronts are
24-196499
Back 33-187174
I just put these on my 2011 - the front anyway and the 24-196499 where the ones I ordered. I used the 5160's on the back.
that part, according to that web site, if i am reading it correclty is for only up to an 09
i have a 12
I am not sure what those other part numbers are for, did you already order and install these? If not, just double check with whoever you are ordering for to be sure the ones you are going to purchase will fit :)
I compared the numbers @velonidy posted to the bilstein catalog and also this post that [MENTION=66316]1engineer[/MENTION] made here: http://www.toyota-4runner.org/5th-g...-lift-road-performance-only-2.html#post982319
It seems to all be consistent for our 2010+ 4runners.
i have a 12
You're not reading correctly! :)
There are two columns, left one for 10+ and the right for 4th Gen. It's confusing, I had to look twice.
With airbags installed and at lowest setting is the rear higher than stock?
Bought billstein 5100
Wondering if the .85 is still the proper setting to level or because of airbags have to go higher?
Thanks in advance
2012 te no kdss
only 1 way to truly know for sure and that would be to take measurements before, install the airbags first, take measurements again, then install the fronts appropriately keeping in my mind how level you want it to be.
Thanks in advance
2012 te no kdss
I had firestone bags on my Tundra and they did NOT increase right height until they were activated
2019 trd orp
Bilstein 5100s at 1.75 setting up front stock coils.
Bilstein 5100s out back w/ stock suspension.
Went w/ Nitto Ridge Grappler 285 70/17 Cs. TRD Pro wheels. No wheel spacers.
Measurements before In inches:
Front Passenger 34 5/8
Rear passenger 36 7/8
Front driver 34 1/2
Rear driver 36 1/2
Measurements after in inches:
Front passenger 37 5/8
Rear passenger 37 7/8
Front driver 37 1/8
Rear driver 37 3/8
Installed at Rock your 4x4 in Knoxville, TN. Very knowledgeable/experienced shop. Had to trim a little off the front and push the fender liner but no rubbing.
delislerebecca
