The spacers are 1.25" the total lift is supposed to be about 2.5", is that going to matter?
I ordered the Daystar 2.5" front 1.5" back leveling kit from 4 Wheel Parts and got it in the mail today but the package for the rear said FJ Cruiser Rear Budget Boost. After calling the service department it turns out there website is screwed up and matches the wrong part up when you enter the vehicle info.
Anyway they got it straightened out and gave me the option between a 2" rear spacer instead of the 1.5" Has anyone done a 2.5" in the front and 2" in the back? I am wondering how this will look, I guess the rake of the truck will be somewhere between stock and what the 2.5" and 1.5" would be right?
Also, is the actual lift of the truck greater than the size of the spacer or does a 2.5" spacer result in exactly 2.5" in lift?
What if you have a 3" OME lift and then added the Daystar leveling kit? I traded out my leveling when I put the lift on because of my fears of CV joint issues. Was I right in playing it safe? Or could I have both? Not my area of expertise.
i really do not recommend this. i tried *part* of the Daystar kit on top of the OME, with near disastrous consequences.
stick with one or the other - don't do both (unless you plan on a lot of other mods to compensate for it ... in which case, i'm still not sure it'd be a good idea).
Thanks, thats what I was thinking too. Thats why I removed the daystar and replaced it with the OME. Its just hard knowing I have a paid for 1.5/2.5" inches sitting in a box =/ Going bigger is always tempting. Thanks for the second opinion, its what I needed to feel right about my decision.
Edit: crap now I saw 4runner8's comment...now I'm all sorts of confused.
you can not go more then 3 inches without creating a custom brackett lift. if you are 4wd and try to combine lifts it will def. fail.... even 2wd can cause big problems b/c there will be absolutely no more down travel and it will screw up all your driveline components and cause a horrible ride on road, and nightmare of a ride off road. if you want a lot of lift go with a full 3inch with coilovers then a 1.5'' BL
agreeing with you guys, but i think it's important to emphasize that OME WITH Daystar is not a safe/good combination. go with the OME and body lift. sell the Daystar kit.
i think 4runner8 was just saying not to worry about the CVs with the leveling kit ...
as for paying for the Daystar and it just sitting in a box - why not put it up for sale in the classifieds section? i'm sure someone here would buy it from you!
