Leveling kit preferences
Gstick
Member
I searched on this forum about front leveling kits for the 2010 4r's, and I'm just curious if one brand is better than another. (Cornfed vs Toytec vs Daystar) I would like to get rid of the front end sag on my 2010' SR5 4x4. All opinions are welcome!
Are they all equal in terms of fit/finish, or quality ?
All they are, is a 1 inch thick spacer made of aluminum, plastic or rubber that goes on top of the spring. I inch spacer gives about a 2 inch lift.Nothing exotic or high tech involved here and never read of any problems with them.
Toytec is a sponser on this site,made of aluminum and who I bought mine from before I changed suspension.Raised my front 1 3/4 inch actaully.Worked as advertized and no complaints!
What kind of 4runner do you have?
It is a 2010 SR5 4x4. For some reason, my front end looks lower than other new SR5's that I've seen. I'll need over 1" to make it level. (Probably closer to 2") Are there any adjustments, or bolts to crank up so I can raise my front end ?
I am a little confused about the spacers. Velocity Offroad makes spacers that bolt on top of the strut assembly. (no need to disassemble the coil springs) Does this do the same thing as the spacer that goes on top of the spring, and under the cap ?
