I did a mild lift a week ago and haven't had any huge problems - one loud clunk on the highway after my alignment, and sometimes an occasional clunk that I used to hear if I accidentally hit full lock still kind of turning the wheel hard.
I noticed today that what I believe is the upper ball joint (below the UCA's) seems to be leaking a little bit. Not too concerned about that (should I be?), but then I noticed my front left (where I heard the first loud sound from) lower ball joint is leaking. Not only is it leaking, there is also grease on the bottom of the LCA (picture). I am guessing it may be exiting the LBJ with velocity and depositing there, but I could be way off.
What can I do? Replace that joint? If I replace it, what can I do to reduce the stress that caused it in the first place (besides eliminating the lift)? Should I worry about causing further damage to something else via normal highway driving in the meantime?
