Front LCA Rebuild
runokc
Hello all! I am wanting to replace the bushings and the ball joints on my front LCA's - it is an 06 V8 4WD about 170k - 2" lift
I know the ball joint is discontinued through toyota, so I need a recommendation for the best OEM alternative, and the best polyurethane bushings, I will post the links to the parts I think they are, so if anyone can verify or give me a better option that would be awesome!
Front LCA Bushings -https://www.energysuspensionparts.com/8.3128
Front LCA Ball Joint - Just a moment...
I have Super Pro bushings in my LCA, no complaints and really no commendations either. The reason I went poly is because I don't like the design of the original with the torsional twist of the rubber being the up/down motion. It makes more sense to me to have free rotation of that shaft/bushing, at least as free as it can be, the ideal would be a bearing arrangement like a motorcycle swing arm.
The bushing aren't cheap, about $500.
erinobr2000
