lift kit required
superdave1
I have a 98 SR5 just purchased from an old lady with 80,000 miles on it and want to jazz it up a bit. 15 x 10 with 33/12.50x15 tires. How much lift do I need to get those tucked in without steering clearance issues?
You can probably get away with running 2" OME and a bit of fender trimming. Or 4" with plenty of clearance. I would run 8" rims tho. They will tuck into ur fenders better.
X2 on the OME suspension kit, it will ride and handle better than new.
A 1-2" body lift would give you a little more room in the wheel wells too.
Only because I love this pic
url
Why are you lifting this? For looks? Mild off roading/fire roads kinda thing?
If looks are your main goal, could probably just get away with a 3"bl. If you plan venturing off the pavement at all, go with OME.
Go to the 3rd gen section. They have a nice sticky there that cover lifts and what size tires will fit. I'm running 33x12.50...2" lift...they fit nicely with a small amount of fender trimming...had a little rub at full lock. But if I take it off road, I think I'll add a 1" body lift for insurance.
seltzernator
