Lift kits for 2WD runner
KalihiRunner
Anyone experience on what should I buy?
What I'am looking for:
1. 3inch lift
2.. Don't really go off road(but likes the lift look)
If you are just looking to make it a little taller, like the way it rides and want to fit a little bit bigger tires why not just get a body lift? Way cheaper and you don't need the enhanced offroad capability (or cost) a suspension lift gives. A body lift is usually under $200 bucks. If you aren't wheeling it or pre-running it there is really no need for a suspension lift or upgrade.
Cause BL's are ugly, as a general census.
Spacer lift is just as cheap and allows for change of rake and can just be added to stock suspensiom.
common kits used (manufacturers)
Daystar, Toytec, Cornfed, Supreme suspension, etc
Tires
BFGF's KO2's A/T, duratrax, mtr's, cooper, general grabbers etc
Good size tire for most spacer lifts 265/75/r 16 17 18 etc
Good luck
Now you can be confident in knowing you "look cool" in your 4runner
2001ATL
