Lift kits for beginners...
medicrn
Ok so I have larger than stock bfg at 265/70r17 (on stock 17 rims that came w truck w 17 inch option)
Added a shrockworks winch bumper and lights.
Added weight to front end is rubbing a lot, need to get a lift,
I like the ome option but I can't do a lift by myself. Need to have a shop do it.
Moving to mountain view, CA.
I need to lift my truck for the added weight of the shrockworks bumper and a warn winch, bfg's are rubbing. Want to add shrockworks rock sliders and eventually a rear bumper w tire carrier and a couple gas cans, a hi lift jack.
Found ome kit as follows:
1 x OME full suspension -- $926.99
Front Coil spring options: 886 Heavy front coils 03-09
Front top plate spacers: no top plate spacers
Rear Coil options: Toytec Light superflex rear coils
Rear shock options: 60020 (For Toytec superflex rear coils)
Model year: 03 - 09 4Runner and 07-09 FJ
Add rear shock stone guards (Pair): Yes (+ $28.00)
Assembly of front coils/shocks with new mounts and bushings: Yes (+ $100.00)
Front Diff Drop Kit: 4x4 Add Diff Drop Kit (+ $29.00)
The problem I have is, unlike most people on this forum, I live as a traveling nurse living in hotels and I can not install a lift kit on my own. Need to pay a shop to do the lift.
Where can I go in NJ to get the best lift installed,
or should i wait to move (looking at a job in mountain view, ca) to the Bay Area.
where can I get what I need to start?
And if that where in the 94040 zip code should I go?
4 wheel parts has a shop in San Jose, ca and has a Rancho kit that includes:
Part Number: RANR1336R9
Rancho Suspension 1 to 2.5 inch Lift Kit with Shocks
Front Lift Height: 1 to 2.5 inches
Rear Lift Height: 1.75 inches
Front lift method: Coil Overs
Rear Lift Method: Rear Lift Blocks W/U-Bolts
IncludesFront & Rear RS9000 shocks
Component finish: Silver & Black
Max Tire Size: 285/70/17
Max Wheel Size: 17 X 8.5
Backspace: OE/Stock
If you're looking for a suspension lift kit that's engineered to perform at the highest level off-road & on, built tough to take a pounding, and last for the life of your vehicle, then Rancho Suspension has your kit. Rancho has been in the buisiness of providing rugged off-road products for 50 years, and is a leader in innovative suspension and shock absorber design.
I'm not sure what to do.
Seeing what you want to add I would say go with a true coilover suspension so you can adjust the front height as you add more weight.
As for the install, if you do move to Mountain View, there are plenty of bay area folks, myself included, that would be more then willing to lend a hand and some space for a small fee of well beer.
Good luck with the job hunt.
Agree with coilovers as your answer. I run Icon stage 1 and highly recommend it. There are others too. Spacer lift isn't going to handle the extra weight.
DionicioLives
