lift kits
jackedup
i'm wanting to install a 4"rough country lift on my 93 4runner,it currently has a 2"body and ball joint spacer kit,unsure of size.does anyone know if i can use these seperate lift methods together?want to use rear coil spacers if needed to level vehicle1 1/2 to 2".thanks for any info.
The BL will have no impact, but the BJ spacers plus the other lift may put the front axle shafts at too great an angle.
doesn't the lift for the front drop the a-arms and diff to achieve the lift with a front end bracket,like on a 88 and up chevrolet?if that happens there should be no differance in front axle angles,or is there something i'm not seeing.gonna talk with rough country & see what they say,but still want forum input from experiences.
Rough Country will tell you not to use the spacers. They clearly state to not modify their lift kit in any way to gain more than the designed lift. Except for cranking the tbars which is ok for some reason...
I ran bj spacers on my truck on top of a Superlift kit which is the exact same as a Rough Country (well used to be, they have recently changed the RC kits to make them a little cheaper) and got to the point where I just didn't like them. It's hard on ball joints, TRE's and the idler arm and I got tired of having no confidence in my truck and always having to replace components. Every component change also results in another $60 alignment too. Just last week I removed the spacers and the blocks I had in the back. I like the way the truck sits better already, but I have to do some pounding and trimming now in the front as a have a slight rub with the 36" iroks.
If I were you I'd keep the body lift and ditch the spacers. You should be able to run 35 or 36" tires pretty easily, and any bigger than that you'll end up hating your truck.
workingwheelswnc
