Lift & Lights
cobrakai
So I finally got around to taking pictures of my mods. Quick background:
- 04 4Runner
- 85K
- completely stock till now
Warranty is long gone and I figured it was time to make it more of a truck and less of a mall crawler.
First step was Daystar 2.5/1.5 lift. This was the new version (all top-out). I could not find anyone in south Texas who would touch a spacer lift with XREAS if you had to use a portable spring compressor. Everyone wanted to take off the struts and put them on a wall mount compressor. Of course no one wanted to mess with disconnecting/reconnecting the XREAS lines. Daystar's new design allow for installation without any compression. Planet Pickup in San Antonio agreed to install using this kit. I think this is the ideal spacer lift for the truck. Wouldn't want to go any higher with spacers, and anything less wouldn't be worth it.
Next, BFG 265/70/17 tires. I was really going back and forth between this size and trying to stuff 285s in there. Glad I stuck with the 32" tires. Leaves enough fender gap to look correct, no trimming, and absolutely no rubbing under any conditions. Had to go old school white letters out.
Last, the lights. I purchased a pair of KC Slimlites to mount on the front bumper. Used the same basic concept found here
Instead of having the mounts come out by the fogs, I made longer brackets that come up to the top of the bumper, then out. This install was a PITA. Getting the bolts in, fabricating the mounts, painting, etc. took me most of a weekend (wife was not happy). I was trying to avoid drilling into the bumper, but after getting everything mounted, there was too much vibration when driving, so I had to add an additional bolt directly under the hood on each mounting bracket to really make it solid. I wired everything up to a factory toyota fog light switch next to the diff lock. Goal was to try and keep everything looking as stock as possible. The KC's really light up the night (100W bulbs). Definitely can't use these on the highway.
Now that lift and bigger tires were on, you could easily see the skidplate. You can't see it in the pics, but I followed someone's advise and prettied up my skidplate (was beat-up from various offroading without lift). I primed it, then spray painted with truckbed liner. Looks almost new (except for the big dent). Stuff seems pretty tough. We'll see how it holds up.
And Finally.... Pics:
I really like the look of the minor lift, and the tires. I'm thinking I'm going to have to do the same with mine!!
Please report back what your previous MPG was, and what it becomes now! This would be the only thing that would deter me from doing the lift. So hopefully it's not a bad loss.
I say nice choice of lift and nice choice of tires (looks tough , although I like blackwall out ) & lights ..... sweet looking and not overkill !!!
Did you notice it feeling a little more tippy than before lift ?? The old 2.5 / 1.5 kit seemed to provide more lift than the topout does. People have said this lift now comes out to measure what they advertise.
Are you going to leave the boards on ?
That is slightly more than a minor lift , you really can't go up much higher with these trucks with really doing some modifications.
OH I forgot ...... Welcome to the site :D
Honestly haven't noticed a major drop in MPG. My commute is mostly highway. I was averaging 17-18 with old tires / no lift. I think it may have dropped .5 to 1 MPG at most. I honestly thought the tires and lift would hurt it more than it has.
As far as stability, I haven't noticed any real change there either. My other vehicle is a BMW M3, and I tend to try and drive the truck the same way :D I think the XREAS does a reasonable job keeping it stable in the turns, even with the lift.
I have a young son, so I have to keep some sort of boards on or he wouldn't be able to climb in. Sliders might be the next project.
Very Nice!
Excellent choice of mods. Looks great but not over-done to detract from the DD capability.
:cheers:
I was going to purchase the daystar lift from here but planet pickup gave me a better price on the kit and install.
I never took measurements before the lift. Measurements after:
- front wheel center to bottom of fender = 21.5"
- rear wheel center to bottom of fender = 22.5"
- bottom of running board = 11"
Looks awesome man!! I just installed some KC slimlite 130w lights myself, I have the factory switch may I ask how you wired it? I didnt wire mine to the factory switch yet, just put the KC switch under the dash for now.
P.S. Not sure how you feel about removing the running boards but in my opinion it would look a lot better with them off, only like 3 or 4 bolts or something take one off step back and see what you think about it.
P.S.P.S. lol just read the bit about your young son, maybe taking the boards off isnt a good thing for now.
Wiring was pretty straight forward. Followed the diagram from here
Another reference here
Couple of notes:
- switch has a ground and three hots
- top pin is for 12V source. Depending on where you connect this determines when you will be able to activate the lights. I originally wanted to have them come on when the fog lights were on. Gave up on that and just found an empty 10A fuse in the driver's kick panel fuse block. Lights are only powered when key is in run position.
- 2nd pin goes to KC Relay
- 3rd pin goes to switch illumination. I just tapped a line from the neighboring switch (diff lock). Problem is the switch is always illuminated and does not dim. When I have some time, I'm going to try and find a wire that ties to the dash illumination and tap that.
- 4th pin is ground. Just wired to one of the dash bolts.
The switch fits right into the blank between the diff lock and the VSC switch. Everything is tie wrapped and fed though the rubber grommet directly behind the parking brake into the engine bay. The rest I wired per KC instructions.
Let me know if you have any more questions or need pictures.
ghengiskhan
