Lift Measurements... Thoughts?
Stellar
All measurements were taken from the center of the wheel to the edge of the fender. DF (Driver's Front), DR (Driver's Rear), PF (Passenger's Front), PR (Passenger's Rear)
My stock supsension/stock tire measurements are:
DF- 19"
PF- 19"
DR- 21.25"
PR- 21.75"
After installing Bilstein 5100s on the lowest setting w/ Toytec springs front and rear. Also, 265/70/18 tires were installed. Measured a week after install.
DF- 22"
PF- 22.25"
DR- 23.5"
PR- 24"
Months later I installed ICON UCAs and moved the spring perch up to the second setting (0.85").
DF- 22.25"
PF- 23.5"
DR- 23.75"
PR- 24.5"
I certainly have the driver's side lean going on. Any input from others with similar lifts?
Install Daystar one spring spacer under the driver side rear spring. That is the cheapest & easiest starting point.
CoaterZ_FL
