Lift question: Bilstein 5100 and rear spacer
bob3dsf
hey all, have a couple questions.
Finished my lift today with, FJ coils, the 5100's at 1.75 and a 1.5 rear spacer. I used the spring compressor-less method found on the 120 site.
Should I have new, longer rear sway bar end links?? I had to loosen the sway bar mounts to pivot it up a little and the end links were still kinda tight, and passed through their mounting bracket at a bit of an angle. I know they articulate a little but was wondering if that's right, I can't see how it wouldn't be due to the lift. They did weep a little fluid from the ball joint on the bottom.
On the rear shocks I had to cut my stock ones off. Couldn't budge the top nuts. The old ones had 3 bushing seats, and the 5100s came with only 2 and 2 new bushings. I started to reuse the original seat that fit on top of the lower bushing but I had trouble getting enough threads through to get the top nut on, and when I did the lower bushing was compressing funny. I took that stock seat out and just mounted the bushinge directly against the frame mount. That sound kosher?
Here are some picks. I'll try to post the lift measurements later.
Still have the stock tires/ I'm getting some 265/70/17' s in the next few days. And, I still need an alignment. Anything look grossly out of whack here? My camber clearly looks out... but I didn't take any pic of that....
IMG_20150608_201038_333_zpsfwh7bsi2.jpg~original
Here's the front shock top nut. I tried to make it look similar to the original (I counted exposed threads) but I wound up tightening until I got a good bit of resistance.
IMG_20150608_131332_971_zpsx64sk09r.jpg~original
Thanks for opinions.. :)
edit: forgot... new top hats on the front too. I just took the whole coil assembly out, those top nuts were stuck too (and none of them were very rusty looking, go figure).
Looks good! I've been running the same setup on my 4th gen for over 70k miles now. The only other thing I added was some SPC upper control arms so I could get the caster in spec (above spec actually). I've been wanting to get some longer rear swaybar links (I'll probably just cut and lengthen them myself) one of these days. So far, they are hanging in there just fine.
Thanks. I'm always a little nervous after fixing stuff because I wonder what I screwed up and didn't realize.. LOL!
How hard was it to get your caster set on the OE UCA? I've read mixed things on this with the 5100's at 1.75. I went with that setting after reading a lot of folks reported having no issues getting their alignments.
H.Sikina
