lift rear with RAS
Emman
Hi,
I install 2.5 DS front spacer on my 08 limited v8 and I keep the rear stock because I want to keep my ras.
Now I want to lift the rear ( 1.5 DS ) but if I install the spacer i can't keep my ras ?
Should put my ras on the HI and pull out the fuse ?? ( i will have a light in the dash i think )
what can I do ?
Send Ark_swamp_rider a pm. I believe he's getting 1.5-2" of lift with RAS.
Correct. You can adjust the sensors on the rear to make the normal position higher. Same concept as what you're talking about, but no dash lights and the system still functions as normal. When I went with around 1.5", my shocks have a tendency to bottom out.
There are two sensors above the rear axle. These are used to adjust height. I'll post a pdf with instructions later today that'll show how to do this.
charlesz
