lift setup
BunchDub11
Alright so I'm putting in 5100's soon. Everyone talks about what setting is the best for a small rake or being level. But that's not my cup of tea, I want my front to be 1inch + higher than my rear. But want to avoid putting too much stress on my cv's. If I have super flex coils in the rear(2") and run 885 or Eibach up front what setting should I go with? Is this even going to be possible
I don't think the 5100s are supposed to be set to lift settings with lift coils, you may overextend the shock. And 5100s alone with stock springs might not even get you level much less front rake.
The best thing to do would probably be to get a 1/2" top spacer (1/2" spacer=1" lift) for the 885s/eibachs or just get adjustable coil overs instead and crank them all the way up.
I'm running 5100's on lowest setting, 885's, and 1/4" thick top plate spacer. This setup has given me 3.5" of lift in the front. 5100's + 885's should put you at 3" which will have the front 1" higher than the rear. I'd start with that.
jisoo200
