Lift with bilsteins?
e-caban
So I just went bilstein all around on my 2000 t4r (hd i think.. there the regular yellow ones) I wanted to get the toytech 3 inch lift, spacers up front with ome coils in the rear. I was wondering if I had to get bilstein 5100's to lift or if i could use the shocks I just spent $400 on.
I am running the same shocks on my set up, front I only have 99 tall springs with a 0.5" thick top out spacer. but the rear I have the OME 890's. No problems in probably about a year with this set up. I do plan to upgrade to the 5100's up front to help level it out a bit more though.
For the front you should be fine. Are you looking at the top-mount spacers or the ones that compress your spring. Either one should work with stock type shocks. For the rear you may want to go to longer shocks with a lift.
youngrk
