Lift
Dim_Sum
Im Looking Into Getting A 2-3 inch Lift For My 1998 T4R SR5. Tried Off Roading Last Weekend And Had A BLAST!! But Im Considering These Ones: Lift Link , Has Anyone Installed These And Any Pro's And Cons's About These, I Dont Do Any Hardcore Offroading. Also Would These Affect The Driveability, And DriveLine/Drivetrain Components?
Thanks In Advance For Any Advice And Comments
I have a similar setup by Daystar, a spacer kit...it made the ride on stock shocks a LITTLE more bouncy, but surprisingly softer on dips and bumps...so it goes up and down more than it used to, but its not as harsh as it used to be...
I havent taken my truck offroad cuz im only a 2wd :( i just got mine for looks...
the driveability will not change much, just a slightly higher center of gravity, so rolling is easier but I can BARELY feel a difference...
it does NOT change any driveline/train components at all...
Thanks ill check this site out
JustAnotherT4R said:
have you tried looking at Toyteclifts.com? my friend has a revtek kit on his Tacoma. but he doesnt seem to like it much.
Thanks, ive been considering the daystar ones as well, i dont offroad it much, mainly i want to lift it is to clear so bigger tires, did u do the install yourself? was it hard?
thanks
i sure did install it myself...
you will DEFINITELY need about 5-6 hours...a big floor jack, some jackstands, spring compressors (the kind that hook on the outside of the spring), and an extra set of hands would be nice...
an impact would help a lot too, to tighten down the spring compressors...helps A TON
With This Lift Has Anyone Tried Fitting 33's On?? Any Rubbing?? Im Planning To Do Some Light Offroading
I got the 3 inch OME lift kit from toytechlifts and I like the way it looks on 265/70's, but I am getting 33's next week will post some pics when I get them put on.
