Lifted 4runners and ATF Fluid Level Check
blackfc3s
All,
I recently lifted and level my 4 runner and now Im going to be replacing the ATF fluid in via the lines near the radiator.
Anything I should note when Im doing to fluid level check at the end? Will the leveling of my 4runner mess anything up?
All,
I just did the transmission fluid complete drain and refill this past weekend, its lifted probably 3.5" front 2.5" rear didn't even think about the fluid check level since its lifted. Wife has not had any problems thus far and I really don't feel I will have any. I made sure to put a little extra fluid in the transmission so that when I got the AT-Temp light to come on and I unbolted the level check bolt that some would come out so I didn't have to shut down, add and restart.
There's an acceptable range around the spec, consensus on here is that lifted/leveled within reason is fine to check level as manual says (level ground too). Now if you really want to be a stickler you could jack up or block up whatever end you need to get the pan perfectly level but shouldn't matter.
MaximussK
