lifts
yota runner
has any1 tried the 3" lift/ 1.5" off ebay for 2002 4runner?
im wantin sumthin for more looks than play it is my dd and i just wanna add
32s or 33s
That is a simple spacer lift, probably won't ride very well. I would suggest you save about $350.00 and you could do something similar to what I did.
http://www.toyota-4runner.org/3rd-gen-t4rs/65845-fightmans-build-thread-3.html
If you scroll down, you'll see my most current lift mods. I used Tundra struts with a top plate spacer, a differential drop kit, and Landcruiser coils with some skyjacker shocks.
The ride is great, and the slightly raked stance is nice too!
I tried to find the one on your first post but all I saw were spacer lifts for the most part. However there was a set of lift springs that looked like my old FOR gen II lift springs...had tight wound coils at the top. Not sure what thats called. Maybe a type of progressive but not sure.
I used one the same daystar kit on a 96 4runner it worked OK, plenty fine for the street but tough on the ball joints off-road (from my experience anyway) as with most spacer kits. I'm sure there are smoother riding kits out there. I skipped the whole IFS suspension kit this time around on my current runner and went sas to meet my goals. If you're looking to keep it cheep look up the p/n on daystars website and then give 4-Wheelparts a call and you should save about $30 if you don't want the shock boots that your ebay link shows.
johnnya
