Light Bar Problem (Help)
Mike_Geary9
Earlier today both my rigid dually reverse pods, and my 30" bar were working perfectly fine. Just went out to run an errand and when I turned on my duallys switch, there was no light... I got out to look and they were on but at a very low power and not shining enough to light anything up... after noticing this I then tried my 30" switch and again, no visible light was cast out so I went out to look and the outer portions of my flood/spot bar were lit very dim but the middle portion was not lit at all, and at times the light bar would flicker.. it's almost 9PM and pouring rain so I haven't had a chance to look at it yet but will be first thing in the morning.
the bar and dually wiring is separate and both switches are hooked up to relays as well, so what I am thinking may be the problem is the ground connection.
and the only thing i have done in between them working and not working properly was reset my MAINT light because i changed my oil yesterday (if that has anything to do with it)
*sorry if this is not where I am supposed to post, I don't really post on here - I just mostly read up on other posts throughout the 4R community.. if i should post this elsewhere please re-direct me.
seltzernator
