light install help
2000runr
Guest
before i install these 4 piaa's, can anyone give me their opinion on the best way to hie the wiring? 4x4 shop and dealership here are saying there are a few ways, one of which is drilling into the roof which im very skeptical about. somehow the wiring has to "jump" from the roof rack to the inside of the vehicle in order to get to the battery. also, any suggestions on mounting a quick release in case i need to remove the roof rack?
If you pop the end covers off of the Roof rack there are some yellow plugs, you can remove those and run wires through there, just make sure to add some silicone. Another option is through the sun roof drainage tubing, but that only works if you have a sunroof:D
