Lights are stuck on...
elcidsurfer
Hey y'all,
Got a new troubleshooting issue for us 1st Gen T4R owners. The "driving lights" wont go off on my '87. My white headlights go off, but the yellow front and red rear lights are stuck on and so is the annoying high pitched buzz even when I pull the keys out and close the doors. I ended up pulling the negative cable on the battery while it's parked so I wouldn't drain the battery. I'm not sure what happend. I parked it on Friday with the lights off and then today they were magically on and are stuck on. Any thoughts? Switch, Fuse?
Thanks,
ElCid
yeh, id think switch as well.
too bad, as theyre expensive. being a combination switch.
i would remove the steering wheel, and make sure the switch is tight. ive seen the screws come loose, and cause weird things to happen.
goddesszilla
