Lights issue
beliboy32
Here's a good one. Dome light works rear hatch light works ...MAP lights dont.
The back story the maps didn't work when i bought the car. I figured the bulbs where burnt out. I finally got around to changing them all to LEDS. Upon further investigation the bulbs in the maps where perfectly fine but no power at the maps.
So what up here ??? cause all the other ones work (i fugre they are all on the same fuse/circuit)
Nothing is THAT simple. But you are on the right track. You didn't say what year you have, but I only have the 02 EWD anyway. Did you actually check for power/and or Ground at the map lights? Here is the diagram if you know what to look for.
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/ewdtmc2/ewdtmpdf/ewdsourc/2002/024runne/systemci/023il.pdf
:popcorn:
:popcorn:
Sorry i have an 2001 4wd sr5. ill look at the diagram and hit you up if i have anymore questions thank you
seltzernator
