limited bodycladding (bottom half of door molding)
yung
Hey anybody out there know where I can get 1999-2002 limited edition door body cladding? It's on bottom half of the door on the outside available only on the limited. Willing to buy for a reasonable price!
RoySharif said:
Isn't the door cladding the same with all model grades of the 3rd gen?
Nope. I believe the cladding never changed on the limited throughout this run. But it did on the other models. On my '99 SR5 - Highlander, it was just the thin, black plastic trim.
When they started adding the silverish colors to the Highlander offerings (if they even still called it a Highlander edition then), they did have the same body cladding then, as they did on the Limited.
I thought I saw a few black and green Highlander editions that were later model years than mine, that may have had body colored cladding, but it still didn't seem to be quite the same cladding that was available for the Limited.
And, I think most of the SR5's had less cladding even, than the Highlanders. Some with just a chrome strip?
I see. I thought it was the same for all model grades of the 3rd gen because the japanese-spec hilux surf N185 series (3rd gen 4Runner in North America) has the body cladding for all the model grades (from the base model SSR to the top of the line SSR-G).
Thanks.
I think pdoel is right. My '97 SR5 just has a thin chrome strip around the wheel wells and it's causing me some grief because I want to remove the running boards, but the boards have a trim piece that rises up a bit on the rear of the front wheel well and the front of the rear well. If I remove the boards, the chrome trim won't cover the entire fender and I'm afraid it will look silly.
