limited running boards
BP4Rnr
I'm looking for a set of running boards for my 17 limited 4Runner.
Has anybody put on the, Trail Edition Running Boards PT938-89100
Will they fit.
Where are you located? I have some boards on my limited that I'll be getting rid of in the next couple weeks when my sliders come. I'm in north louisiana if you're interested.
I have a set from my SR5 that will fit your limited perfect. Located in Nj
Fyi, the running boards are the same on the SR5 and limited, but the mounting brackets are not. I don't believe Toyota sells them separately. If I recall, its the front mounts that are different.
Many websites fail to mention this. I sold my stock running boards to a guy on here and we found out the hard way.
The mounting is most certainly different on the Limited. I ordered a set of N-Fabs and went to bolt them on and the mounting brackets were not correct and the bolt configuration on the front bracket is different altogether. I later found out there was a totally different part number for the Limited. The 2010-2017 Limited IS, however, the same as the 2010-2013 SR5.
No way, bro. Mine are already off. He can have them. You have to wait in line to unload yours!
That's interesting as the 13 SR5 shares the same rocker panel. I know the front mounts are deeper on mine. Pics tomorrow
