FactoryRide
I think the short answer to your question is NO.
The Motor Vehicle Safety Act's "make inoperative" provision (49 USC 30122(b)) prohibits manufacturers, distributors, dealers, or motor vehicle repair businesses from knowingly making inoperative, in whole or in part, any part of a device or element of design installed on or in a motor vehicle in compliance with an applicable motor vehicle safety standard.
If curious, see this 2011 letter from the NHTSB:
https://lesschwab.com/content_files/TPMS_letter.pdf
Here are two interesting responses found in the letter to questions from the Tire Industry Association:
[TIRE INDUSTRY ASSOC.] "Scenario #1: If a motorist is made aware of an inoperative TPMS sensor and declines to purchase a new one, does the service provider knowingly make the system inoperative and violate 49 USC 30122(b) by removing the dead or damaged sensor and replacing it with a standard snap-in rubber valve stem?"
[NHTSB] "Our response: For the purpose of this response, we assume that you are referring solely to TPMS sensors that are integrated with the valve stem. Moreover, we assume that the sensor was inoperative before a customer brought the vehicle to the repair business. An illuminated malfunction indicator lamp could be an indication of an inoperative sensor. We also assume that you are describing a part within the TPMS system that cannot be repaired. In that event, a motor vehicle repair business would not be violating 49 USC 30122(b) by removing an inoperative or damaged TPMS sensor and replacing it with a standard snap-in rubber valve stem. The removal of a malfunctioning TPMS sensor that is integrated with a valve stem would not violate the "make inoperative" provision because the element of the system was already inoperative. However, a motor vehicle repair business that goes on to make any other element of the TPMS system inoperative, for example, by disabling the malfunction indicator lamp, would violate the "make inoperative" provision."
[TIRE INDUSTRY ASSOC.] "Scenario #2: If a motorist purchases a set of aftermarket winter tires and wheels and declines to purchase new TPMS sensors, does the service provider violate 49 USC 30122(b) because they would be installing assemblies that knowingly make the system inoperative?"
[NHTSB] "Our response: In this scenario, we assume that the vehicle has a functioning TPMS system at the time he or she purchases aftermarket tires and wheels. In that case, a service provider would violate the "make inoperative" prohibition of 49 USC 30122(b) by installing new tires and wheels that do not have a functioning TPMS system. To avoid a "make inoperative" violation, the service provider would need to decline to install the new tires and rims, use the TPMS sensor from the original wheels (if they are compatible), or convince the motorist to purchase new TPMS sensors and ensure that the sensors are properly integrated with the vehicle's TPMS system."
Thank you for that!
Dude- I had an extra sensor that i had in Corpus- You should have said something and i would have given it to you.
I wish I would have known!
Just look on Ebay!toyota tpms 107j | eBay
The ones that fit our trucks are PMV-107J and are made by Pacific and are used on at least 30 different vehicles so there are plenty out there .I think they get them out of totaled vehicles as alot out there. It's crazy that there is such a mark up from the dealerships on these things. Or you can just add "new TPMS 107J" to the ebay search and find brand new ones for just a little more.
The set I have now I bought on Ebay and have worked perfect for the last 4 years as I still have my original set in my shed out back away from my truck so they don't transmit. I had two sets of wheels for awhile and took them back out when I sold the wheels.
I think I read the batteries in them that transmit are supposed to last 7-10 years and I don't believe the batteries are user replaceable .
As far as programming them into my TPMS ECU ,Discount Tire has always done mine for free and takes all of 2 minutes with a Bartek tool .
My current tire shop doesn't have the tool to program it and Toyota charges out the ass to reprogram it. I'll check that link. Thank you!!
