I am going to check the ratio before I purchase. what are my options? I wanted to stick with stock toyota but not if means a LOT of work.techno said:Good luck with the conversion, that is a massive amount of work to do when there are better options available. Are you getting the correct gear ratio or are you swapping those out too?
rubbman said:I am going to check the ratio before I purchase. what are my options? I wanted to stick with stock toyota but not if means a LOT of work.
MORE WIRING NOOOOOO!!! I still haven even got my lights working yet. Im dooomed. So they made a locking rear for the 4runner? I will get one of those instead!techno said:If you want to stick with stock Toyota parts and minimal work then I would source a 4Runner locked rear end, not a Taco one. Your one the right track with doing a complete swap, thats far easier than doing just the 3rd. There's plenty out there, you just have to find the right price I suppose. Then its a simple matter of doing the electrics.
3.4 w/5spdtrd_4runnin said:Finding the gear ratio of your truck is somewhat difficult as the axle codes aren't much help in the newer trucks. What I can tell you is that all e-locked rear ends have 4.30 gears and your truck does not have 4.30s. Most likely 4.10s but I can't be for sure without knowing what engine and trans you have.
rubbman said:3.4 w/5spd
Jordan Petry said:Also, I believe that the automatic 3rd gens with the rear e-locker had 4.30s whereas the 5spd version with the locker had 4.10s
Someone correct me if I'm wrong.
My 96 is a Limited with 16's how can I tell if it has the e-locker?
also I have a 94 I am trying to find out what rear it has mabey some1 can help- vin= JT3VN39W0R0139692 (v6 sr5 auto 4wd)
You're wrong lol.
ALL e-locked trucks had 4.30s.
