Instructions needed on how to go from 4HI to 4LO with differential locked. Stop or slow roll (under 2-3mph) in 'N'. Select 4lo and wait for the lights to stop flashing. If it beeps slow down more or better yet stop and try again.
Also, do most people try to drive with 4LO and then if you're still stuck, then lock the differential? I think most lock the diff in the beginning. Are you talking about off-roading or driving in lots of snow? IMHO 4lo has limited value in snow driving. Buried in a snowbank is one time and even that's a "maybe".
Need also the steps to switch back to 4HI. Assuming you're coming from 4lo locked you have two choices: Unlock the diff, then stop, place it in 'N' and select 4hi. OR stop, place in 'N' select 4hi. Then unlock the diff. What I have found to be important is one thing at a time, in other words complete the lock/unlock or the 4hi to 4lo to 4hi. Make a selection, wait until the dash lights are solid, not flashing, and then make the next selection.
Does that help?
:cheers:
Thanks to those with the tips.
So it sounds like I can also lock the differential for 4Hi. Yep
Sounds like shifting from 4Hi to 4Lo (and back) requires shifting to neutral. Correct...
Locking the differential does not, but one should be stopped before pushing the differential lock button. Not necessarily. I lock and unlock 'on the fly' all of the time. I am sure the manual suggests some max speed for locking and unlocking the center diff. I don't know what it is. I don't lock or unlock above 50mph or so. Once locked (or unlocked) there is no speed limit. 4hi 'locked' can be used at any speed. 4lo is of course limited to the top-speed of 4lo. The caution I would give about high speeds in 4hi 'locked' is the vehicle doesn't handle quite as well with the diff lock engaged AND you'll receive no assistance from VSC should you begin to slide.
Right?
This is for snow driving, in case I get stuck.
