Long Brake Pedal Travel on 2001 4Runner with 231mm TBU
kylethomas
Registered User
I currently run the 231mm Tundra Brake Upgrade (specifically, the PowerStop KC2324-36 Z36 kit) on my 2001 4Runner with 34" tires. Ever since installing ~7 years ago, I've battled long/low brake pedal travel until the brakes grab. I usually have to pump twice in order to get them to stop the way I want them to. I've followed all of the usual advice: upgrading to steel-braided brake lines, adjusting the rear drum brakes, driving down a gravel road and engaging the ABS, bleeding with the ignition on (including a professional bleed), but nothing seems to fix the pedal travel. To be clear, the stopping power is GREAT once I pump the brakes up, but it makes quick stopping in traffic a bit sketchy.
My theory is that the ABS brake pump that comes stock on the 2001-02 4Runners simply cannot supply enough brake fluid to the 45mm pistons on the larger 231mm Tundra brake calipers. I'm considering swapping back to the stock calipers with 43mm pistons to see if that improves the pedal travel. I'm not too concerned about warping rotors or brake fade since most of my driving is around town with no hills.
To other 01-02 owners that have done the TBU, what is your experience with this? Have you noticed issues with pedal travel since installing larger calipers?
