greasefingers, et al,
Thanks for the link on changing out the pads, it came in handy., My new pads came with instructons in about 12 different languages, however, tghe pictorials and writing was really small and had to read with my fading eyes, but that's another story.
I swapped out the old antirattle shims for the ones specified in the TSB (part# 04945-35120) and installed new pads -OEM ( part# 04465-35290) I have just over 61K Kms on the truck now so I figured I would be doing a brake job at in about 15 - 20k Kms down the rod anyway, so might just as well do it now.
Total cost here at Dealer in Ottawa was $142.70 CDN including taxes.
It took me about 2 1/2 hours but I was in no a hurry, could have done if faster but the "antirattle w/hole pins" (that's what they are called in the manual - the two pins on each caliper that have to be removed to get at the old pads) were really stubborn to get out so took my time.
I totally removed the caliper on the left - driver's side as you had suggested, greasefingers, in order to retract the 4 pistons using a "C" Clamp before inserting the new Pad/Shims combination. On the right side I found that I could get my "C" in place without fully removing the caliper, just loosened it a bit so I could more easily remove and insert the pads - learn as you go. so the right side went faster than the left.
I also learned to take a couple of wheel lugs and tighten on the hub to hold the rotors in place. I found my rotors wanting to slip down on the hub with these lug nuts making it difficult to get the new pads seated properly. So I recommend hand tightening a couple of lug bolts on the hub to make things go earier.
The big question, was it worth it? I found that my brake pedal response has raised up about 1/2 inch maybe more and definitelyseems more reonsive much like how it was when I first drove of the lot in '03.
My old anti-rattle shims (the inside ones particularly) had deteriorated quite badly, this may have been causing the problem. The brake pads had 4-6 mm of good surface left but it made sense to change them out while I was in there.
Tomorrow I will bleed the brakes and replace the brake fluid but I doubt that I will see any additional improvement in the brake paedal travel
I will also adjust the emergency brake since I will no doubt be under the truck for some reason or other.
Cheers -Toy-Man-
