Longer rear center brake lne.
Rendell
I have installed a 3 inch leveling kit. I'm running stock stocks, but I'm still a bit nervous about the rear center brake line. where should it buy, and what length should I buy. Or if someone has the part number... I would great appreciate it..
If you are running stock shocks you don't need a brake line.
If you upgrade to longer shocks you still might not need one, depends on the length.
wheeler's off road and toytec both sell stainless braided extended lines
You won't need one.
To test jack your truck up by the frame and let your axle drop.
It won't go any further than that. If there is still slack you are fine.
I have LC Tokico Trekmasters and 8 wraps with removed bump stop. Don't need the line.
You won't need one.
When I put on the lift, I noticed it was a little slack, and it is probably the original line since it looked a little checked.. I'd rather make sure it was right.
Ok, a tacoma, I get it now.. any tear recommendations. I may just buy one off rockauto.com for the best taco year..
Hell no man. Think CHEAPER than that. A Junk Yard or Pick-N-Pull will have it. They're pretty damn small too. If you get my drift.....
I'm pretty sure I've got one laying around. Let me get home tonoght and I'll look. If I do, it's yours for the price of shipping. Sound good?
leolediola
