Looking for Front Coils Only!
Toy4ever
So i have the 3 1/2 inch coils in the rear from Downey and i would like to lift up the front. Does anyone have any good suggestions as to where to get the front coils only? Should i get the OME 881'S? I just don't want to hit the purchase button and realize i have gotten the wrong ones. Any advice and/or referrals would be great. Thanks! :whipping2
You'll need the top spacers with the 881s, otherwise you'll have a major rake. Even with the spacers, you're gonna have about a .5-1" rake. You won't be able to level the front out with those rear coils in case that is your next question. You can only put 2.5-3" of lift on the front without destroying the CV axles.
Don't get the 882s or 883s thinking you can use those and not have to put spacers on. They are tall enough without the spacers, but they will ride like shit if you don't have a lot of extra weight up front from skids, winch, etc..- they are VERY stiff compared to the 881s.
I was looking at Toyota accessories and parts at Rocky Road Outfitters
so my first question has anyone utilized this company before? My second question is when i go to add the front coils to the cart on this specific website it lists Light Duty as being 880 and Heavy Duty being 881. Anyone make sense of this? And Brian when you refer to spacers you are speaking of the 10mm spacers?
No, I wasn't refering to the OME 10mm spacers in this instance, I was referring to the ones that toytec sells with the 881s:
Front Top Plate Spacer Kit - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
And as far as 881s being heavy duty, that info is wrong. They are standard duty for 4runners (although they are a little heavier than stock). The 882s and 883s are condidered heavy duty.
880 - light
881 - standard
882/883 - heavy
