looking for headlight PN
yotatake2
So i went off roading in the desert last weekend and went a bit too hard. My passenger side headlight pivot socket is gone. The actual screw with the ball at the end of it is still there, but the socket it fits into fell out and is nowhere to be found. Does anyone happen to know if I can even get that part by itself? And if so, where can I find the part number for it?
Thanks.
You can buy just the bracket separate This is what I had to do. took the tech 20 minutes to do the part is either 81105 or 81106 depending if it is left or right
bracket retails about 75 bucks plus tax from Toyota
wonder if the tyc headlight parts are interchangeable. from many things I have read , tyc is the only "good" aftermarket one out there.Would be cheaper to buy the tyc and switch the parts to your oem, ( if interchangeable)then keep around the tyc if you ever need a headlight ( based on price of part in above post)
or just switch compltetly to the tyc now, however I have heard that the oem is a better unit
I'll let you know next weekend when I switch them out.
