Looking for part #, 4x4 dash switch?
papapoopski
Just like the title says. I cannot find this part in search.
I have a 2002 with mulitmode.
Looking for the 4x4 dash switch to the left of the steering column, not the 4x4 button on the shifter.
Do you mean the rear differential lock button? Our generation didn't come with a 4x4 switch on the dash, those without multimode have only a mechanical shift, and those with multi-mode have the button on the shifter knob. Probably why you're not finding anything, unless there's an int'l model that had one.
01 and 02 have some changes to the 4wd system
ACC is all electronic as opposed to vacuum system. No rear locker available for this model year.
In addition to the button on the shifter for "awd" there is another button to the left of the steering column below the instrument cluster that locks the center transfer case for 4wd. This is the button I want to replace. It used to illuminate. I pulled the switch and did find that the bulb is replaceable but I'm not sure the switch is functioning properly.
D'Angelo
