Looking for recommendations on decent replacement TPMS sensors for 17" wheels
ddicosmo
I purchased a used set of 2015 Trail Edition wheels for my 2008 SR5 V6 that I'm going to mount Falken Wildpeak AT3s on. Since I'm keeping the stock wheels with all seasons, I need to buy 4 new TPMS sensors. Town Fair Tire wants $25 per sensor and I don't know what the quality is of the sensor they use. Can anyone recommend good replacement TPMS sensors for the 08 SR5 V6 that don't cost alot of money? Thanks,
Dave
I have had No issues with DENSO sensors (from Amz), and Dill sensors from Discount Tire.
Both require the Sensor IDs to be uploaded to the ECU. Takes 5 minutes max.
(These are not sensors that get cloned..) :juggle:
If you get good Sensors that "clone" the IDs you already have, you won't need to upload IDs every time you swap. (Unless you have a TPMS scanner or the tire shop does it for you.)
I really don't know much about how these sensors work... So from what you are saying, I should probably get sensors that are able to be cloned if I plan on swapping out my wheels/tires every fall/spring?
wayblom
