Looking to buy a camper trailer, will the 4Runner be able to tow it?
gkatmar
I'm looking to buy a 22' camper trailer, weight about 3200lbs. I have a 2003 Toyota 4Runner V8 with an OME lift.
Will I be fine with pulling this?
how many lbs are you going to put into the 3200-lb trailer?
i think you can haul a TOTAL of 5000 pounds easy.
The answer is yes, many do and very successfully. Hook a 3200-5000lb behind a 1-ton truck and go. Hook it up to the lighter, shorter T4R and more care is required. The trailer brakes must work properly, the load must be balanced etc.
I am not trying to discourage you, I'm trying to say do your homework. This recent thread has some great tips that came out based on one members scary ride. http://www.toyota-4runner.org/showthread.php?s=&threadid=40816
Good luck and post some pics:D
:cheers:
If you do buy the trailer I highly suggest a brake controller and a sway control device.
Good luck and have fun!
The weight won't be the problem, just minimizing sway.
If you have a later 2003, the capacity is up to 7000lbs with the beefier hitch that's on 2004+ V8s.
