Loose rear bumper!
ew2x4
Hey everyone! I have a new to me 2007 V8 Limited. The rear bumper on the driver side has a gap to it. It's missing a few clips. See below for some pictures. My question is which clips does this need? These?: https://www.amazon.com/PartsSquare-Fastener-Retainer-4Runner-Highlander/dp/B018Q1VDG4
Second, does anyone have a video or instructions on how to add these clips? I'm guessing I'd need to remove the whole bumper?
Here's the pics:
Mine is the same way. It looks to me that the clips on p/n 5256335010 & 5256235010 have broken off or lost their grab tension. Each side has a different P/N.
You can see the piece above about 2:07 in on the video below. Please share back if you figure out another way to fix it.
YouTube
Have a similar issue that needs to be fixed. Curious though, do your by chance have kind of rattle sound when hitting sharp bumps?
I don't hear any weird sounds with this. It seems only 2-3 clips are missing/broken. Maybe your clips are in your bumper?
You will have to remove the rear bumper, luckily it is a very easy process. Pick up a few extra plastic clips before you do it and you will be good to go.
Had the same thing happen to me after backing into a snow pile last winter. I removed all the bolts from the middle of the bumper cover to the wheel well to get a better look. Turns out nothing was broken, just unbolting the bumper was enough to get the cover seated on the original clips.
Jhunt
