Loud clunk each time the gas pedal is suddenly pressed from stop or low speed...
cmilviper
First of all, I just had my 2004 4Runner 4wd jacked up this past Sunday, changing the brake pads. I don't know if that did anything to the suspension or not....
But for the last couple of days, each time I suddenly accelerate from a stop or low speed, there is a loud one-time clunk like something in the suspension is loose?
Everything else seems to be normal driving once going or if I ease into the gas...
Any ideas on what this could be?
Thanks!
Thanks guys....
I'm not sure on the LCA bushings...not too familiar in that area, but will give it a look!
I can for sure lubricate/grease the driveshaft, and give that a try.
10 to 1 it's the driveshaft. a common problem with these trucks in 4wd. if you search for 4th gen driveshaft clunk you can read all about it.
short story is to lube the driveshaft at all 6 zerk points with mobil 1 grease. makes it go away for most people and it's not dangerous or damaging anything.
first thing i did when i bought mine and it went away entirely. i think there is a writeup on this site for it.
Thank you sir...That will be the first thing I check.
Jhunt
