Loud noise coming from front suspension.
knightsfs4
Something I've noticed lately is a loud rattling noise coming from the front suspension any time I go over a speed bump or any type of bump. I went and checked it out and it doesn't seem like theres anything wrong but I know there is. This car really is giving me hell! Let me know if anyone else has had any issues with this.
Jack
Subscribed. I'm curious what folks have to say. My old Accord did this for the last few months of ownership, and I never did figure it out before trading it in.
- Sent via Tapatalk for Android
Stanley,
When you traded it in, did whoever you traded it into penalize you for it? Or just not notice? I'm planning on taking it in because I'm going to trade mine in for something else, I just want to make sure the car doesnt break down on me!!
Yes, please describe better. No reason to trade a car in because of a suspension noise. I had many reasons for moving on from my Accord.
It will just be a matter of locating this particular sound's source. The cost to make it right wont be that bad.
Give us more details of how/when/is your ride stock?/any leaking shocks?/are you missing a bump stop?
Oh and they did not penalize me but prolly did not notice on their drive. It was only certain conditions. (I didn't feel guilty, as they only gave me $2k last year for an '01 Accord with an absolutely perfect body, and everything working great on it despite 130k miles. So I was the one being duped in my opinion..! I'm sure they could have gotten 3k at auction for that thing with no detailing, and likely around $4,500-$5,000 retail.
Sorry.. little rant there..
The sway bar end links are a common cause for a noise like this. Either tighten them or remove swaybar altogether to rule it out. Only reason I say remove it is because it could be the swaybar hitting the coils when fully extended. This is common if you don't have the sway bar relocate.
This noise was caused by the end link being slightly loose. Mainly heard it when going over speed bumps just as you describe.
Update:
I take it to Toyota today and have them check it out. The noise is still annoying so I'm happy to get it fixed. Drop it off and get a call 2 hours later. The guy tells me they cant find anything wrong with it... WUT
Update:
Is the noise anything like what is in the vid I posted? On mine, I was able to push down on the bumper pretty hard and after doing so for a few seconds you could hear the noise. It was very obvious at that point. Do you notice it only when going straight, or only when turning, or at all times? Another thing I noticed on mine, is that if I hit a speed bump straight on, it wouldn't make it, but if I hit it at any angle at all, it would make the noise.
Sounds to me like it's time for a little research on your own narrowing down possibilities and give up on Toyota. Doesn't sound like they've been able to do much for you on these various issues.
I had this same issue. Crazy annoying. Installed the swaybar relocate from Toytec that ARK mentioned and no more rattling over the bumps. Super easy to install and it only cost $30.
Take your skid plates off, after I did my lift, I found the sway bar was hitting the stock skid plate when it flexed. I solved this by putting two washers between the skid and frame to gain a quarter of an inch of clearance.
This is assuming your truck has been lifted.
Stanley,
The chances of getting a deduction in trade in because of a rattle is slim. They might use that as leverage when trying to give you as little as possible, but it doesn't matter. They will most likely take it to auction and they just start them up to make sure they run there. I traded in a Neon once that had an oil leak out of the back of the block. I just cleaned the motor up with some degreaser and let it run a quart low. No issue at all.
Could be sway bar/end links as suggested above. Takes about 15 minutes to remove the sway bar completely, I'd try that to rule it out.
I've also had a rattle caused by worn out m-springs on the front brake pads. Every time I went over a big bump the pads would rattle loudly and it sounded like my front end was going to explode. New m-springs and some brake grease on the slide pins is all it took to fix (about 3 dollars in parts and 1/2 hr of time).
I don't think you should trade the 4runner in because of a small rattle and other little issues you've had with it. I know you want your truck to be perfect and problem-free, but I think you might have unrealistically high expectations. Every vehicle you own is going to have a set of issues that crop up over a period of time, doesn't matter if it's a 4runner or a $60k Benz. Sometimes things start rattling and need to be fixed, such is life.
But if you want a different ride altogether, by all means trade it in. I don't think you'll get any less money for it because of the rattle. I traded in my Volvo S60R for the 4Runner and it had blown spring seats and failing shocks. It rattled like hell and clunked over every bump, but the dealership didn't even test drive it, they just gave me essentially what I wanted for it. Dealerships usually just wholesale their trade-ins at auction anyways.
My truck just starting doing the same thing over bumps. The only issue is the noise only occurs on cold days. I am also interested to see what is causing this. A friend threw my truck on a lift and found nothing as well.
Just took it to Toyotech near where I live. They had the car for 3 days and figured the problem out. The springs that are on the break calipers were missing...weird. Anyway they charged me $92 in total opposed to $350 for toyota just to look at it... I'm happy!
Geez... That little rattle? Glad you solved it. Mine does that too with my Napa Pads + spring clips, but it doesn't concern me in the least. Apparently I can go get the OEM spring kit, but it really doesn't bother me to be honest.
Yours was probably much louder I'd guess however.
Mine is similar. It does not do it at high speeds and usually only hear it on medium bumps like sunken manhole covers or potholes. It sounds more like the sound made when you push and pull on the front wheel when you have a worn out ball joint. . . . .kind of a loose hub sound. I have not figured it out yet, but will probably remove sway bar to test. Anyone think it is the lack of brake pad springs?
Not the pads. I hit some bumps while purposely braking and it still made the noise.
