Low beam bulbs?
06-09: H11
HIDs
03-05: Absolutely not. You do not want to put HIDs in a reflector headlight, it will blind oncoming traffic
06-09: Understand that it is illegal in most states. Usually not a problem, especially if installed correctly using appropriate housing. It need to be in a projector housing to be even remotely safe. 06+ is a projector, but doing it "right" requires a more controlled projector done via a retrofit. If you are in a state that does inspections, having them installed may fail you.
Done right, it is spectacular. Doing it right is also expensive.
sounds great- i need some better lights..lows and highs..do you normally have to adjust your low beams after putting in the hir's?? i dont want to be that guy blinding everyone
also gonna start tracking down some good yellow fogs that actually do something
No adjustment required and I've never been flashed. If you live in the city and want to save a couple of bucks, you could ignore the high beams. I did mine but almost never use them (but they are bright when I do).
