I have an 03 4Runner with DRL's, the low beams have recently stopped working. The DRL's and the high beams both continue to work (both when on and when the stalk is pulled all the way forward) The interior lights do go one when the headlight switched in put in the on position.
I have tried:
1. Jumping the main headlight relay.
2. Testing the switch; Continuity across pins 16, 14 & 13 (I do not have continuity across pins 16 & 12 though which are labeled as having such when the switch is in Auto)
3. Checking all of the fuses.
Could this have anything to do with DRL system? or is that completely independent?
Is there any way for me to confirm that this is not the switch by bypassing/jumping it?
Here is the diagram I have been using for reference.
Any help is appreciated.
I have tried:
