Twan
Senior Member
Hello all, trying to figure out an issue with the '00 SR5 I picked up the other day. I drove it for the first time after dark last night and noticed the headlights were very dim. Did some poking around and it appears the headlight switch on the stalk doesn't do/change anything as far as the headlights are concerned. All the other lights turn on and off like normal. It appears that the DRLs function normally, but that was the only light I was getting out of them. The high beams come on when the stalk is pulled back, but do not come on when the stalk is pushed forward.
What I've done so far:
Checked all fuses, all are fine.
Checked the relays. Both click when the stalk is pulled back, nothing when pushed forward.
Checked the bulbs themselves. Both filaments are fine, lows are lit with the DRLs and highs come on when the stalk is pulled.
Unplugged the DRL module next to the battery. DRLs were off, no low beams when switched on, high beams work when stalk is pulled.
I'm not sure what to check next, or not sure what could be a common failure since this is my first Toyota. I haven't been able to find any threads that address this problem, as all the similar issues seem to be burned out bulbs. Any suggestions?
