Low Oil Pressure Warning Light
Tom Kozesky
Greetings All;
1998 T4R SR5 3.4 auto 4x4...oil changed but a month ago at the dealership along with a transmission flush. Rig has almost 90k on it and tonight the above warning light came on. Has not used oil in past and not blowing smoke. Something always happens when you're out of town. Vehicle will sit till I return home. Ideas, suggestions.......Thanks:mad:
dumb question, but has happened before. Did you check to see if the fill cap is on? Or if they put the proper amount of oil in the vehicle. Don't trust anyone, always double check.
As I mentioned, I'm out of town and won't be able to check it for a few days. I can only hope that the Toyota tech knew what he was doing. I think he knew, as he dropped the skid plate and everything to change the filter. Thanks for your thoughts.
jisoo200
