Unner
So I've got a clunk somewhere in my truck (2001 4Runner 4x4, 195k miles), it sounds like it's coming from the front end or maybe right under the front seats area of the truck. The clunking only happens at low speeds like when pulling into the driveway, going over speed bumps, or turning like in a parking lot.
Other than the noise the truck drives just fine, no vibrations, no loose or sloppy steering, the noise is unnoticeable at any sort of speed really, it drives just like it should on the interstate. It does seem to make the clunking noise If I back up and hit the brakes fast, or do the same thing pulling forward slowly like you would in a driveway and then hit the brakes.
Things that are new:
LCAs (OEM)
LBJ (OEM)
OTRE (OEM)
ITRE (OEM)
Sway bar end links
Poly sway bar bushings
Poly steering rack bushings
Toytec Boss coilovers upfront
LC lift in rear (All OEM and new)
Driveline greased
Rear Control arms retorqued after lift/panhard as well (checked these again last week) None budged.
Front Upper Control Arms retorqued after lift
Steering rack guide retorqued
Sometimes when I step on my sliders to get in the truck I can kinda feel/hear the clunk in them. Other than that I can't recreate the noise by shaking the truck. I always hear the noise when I pull into my driveway. I hear it as the front wheels hit the sloped part (at an angle since I'm tuning) and then again when the rear wheels hit the sloped part.
I'm kinda lost on what this could be. My UBJ's and UCA Bushings don't seem bad and I have perfect tire wear and no poor handling at high speeds which is where I would think any suspension issues would really start to shine, not a low speeds. Alignment is good, and I have no issues getting everything in spec except for the caster, but it's only like .2* away from the stock range.
I have also taken off all of my endlinks and the noise was still there so it shouldn't be anything sway bar related at all. The noise happens in 2wd and 4wd as well.
These are some things that I think could possibly be causing the issue, but I don't want to keep throwing money at it to solve the problem...
1)Body mounts? Do these really go bad? How can I test them?
2)Transmission Mount/Engine Mounts? Seems unlikely but who knows...
3)Frame flex possibly causing unwanted contact somewhere? I've got lots of stuff bolted onto my frame. Addicted Off Road Front Bumper(Noise was there before the bumper for sure), Shrockworks sliders, shrockworks skid plate set. Does this seem possible? How much would a 3rd gen frame really flex pulling into a driveway?
4)Front differential mounting points. I'm talking about right where you would install a diff drop which I do have. There are these rubber washer things (called stoppers per Toyota) The one on the driver side seems a little torn from sitting in oil from oil changes over the years. I believe there are actually bushings in the arms that mount to the diff that aren't replaceable without buying a new arm from Toyota. I searched up and down, but I couldn't find anything on these really. The only people I saw mention them were [MENTION=95069]TBuzz[/MENTION] and [MENTION=10182]smallfry[/MENTION]. Any thoughts on this possible cause?
5)UCA/UBJ. Seems unlikely to me, but possible I suppose.
I appreciate any help or suggestions. I've been searching up and down trying to find what it could be, but I'm at a loss now so I'm turning to you guys for some advice.
LCAs (OEM)
LBJ (OEM)
OTRE (OEM)
ITRE (OEM)
Sway bar end links
Driveline greased
