Lower ball joint replacement recommendations
I had the 555 (Moog packaging) LBJs and they definitely weren't OEM quality.
I bought 555 LBJ's, inner and outer tie rod ends from LROR and will see how they are. The ones I took out were original 21 year old components w/ 222k on them and they were not worn out.
Facts:
OEM lasts more then 150K miles: I and many at T4R experienced
Aftermarket Orielly lasted 20K miles: My neighbor experienced with his tacoma 1st Gen.
Most aftermarket parts are made by 555 and renamed the product.
Avoid 555 as much as you can. Those are garbage.
When I did the LBJ's 5-6 years ago, both were like $156!
If the 555 stuff I got doesn't hold up I will definitely get Toyota next time.
Facts:
That's almost as much as the local stealership wanted for one here... I bought my 98 last March with just over 190,000 for just over $5,000... I have 217,000 on it now and have no record of when or if they were ever changed. I've got a close to 600 mile trip coming up in a couple weeks and for piece of mind I want them done before I go... they should be here on Friday and hope to install them on Saturday..
Got the new OEM LBJ's installed yesterday in the sweltering heat and brutal humidity. If I had to guess these were the factory originals. They were still pretty tight but extremely rusted. I envy you folks who don't live in the rust belt states. After watching Timmy the Toolman's awesome step by step video on youtube I figured this was a job I'd tackle myself. I had started spraying the bolts and castle nuts on Monday and hit them again three times during the week. Glad I did. the cotter pins were rusted solid and could not be removed so I had to snap them off using a breaker bar to get the nuts off. Thankfully the tie rod ends had two holes drilled for the cotter pins so I was able to just drill through the stuck rusted ones to install the new pins after torquing down to spec. I used my buddies garage to do the job and planned on using his air impact gun to break everything free but just as I was going to break the lug nuts free before jacking up my truck I discovered the trigger on his gun was broken. Ran out to Harbor Freight and bought one, put some oil in it and after just loosening a couple lug nuts a seal blew out in the gun. I ended up completing the job with breaker bars and hand tools.
Congrats on successfully NOT busting those 4 bolts securing the LBR to spindle!! Another north-easterner here, lower Hudson Valley.
Bought OEM LBJ, Inner/outer tie rod ends & front/rear springs about a month ago from Conicelli Toyota.
Picked up front/rear KYB shocks as well.
Been spraying all hardware with Kroil for the past 2-3 weeks. Changed out front springs and shocks yesterday. Still soaking those 4 bolts for the LBJ’s as no way do I want to snap them in the knuckle.
Impact guns are tempting but thinking not a wise idea with rusty hardware.
A hazard of living in the northeast for sure!
I did snap a 1/2 in extension trying to break free the castle nut on one ball joint. The 4 LBJ mounting bolts actually came out pretty easy. I was surprised there was zero rust on the threads of the bolts. I used a loaner puller set from Advance Auto to separate the tie rod ends and ball joints...
Advance Auto Parts - Down for Maintenance
made that step super easy with no damage to the tie rod ends.
555's are actually OEM quality for the ITRE, OTRE, and upper ball joints. It's a sealed polished ball design in a teflon retainer seat.
It's just the lower ball joint that needs to be OEM because the 555 version is a greaseable metal on metal design.
Everything I got looked like the original stuff I took out (21 years old, 222k and not worn out) including the lower ball joints which don't have grease fittings.
I gotta say, I've been fixing cars professionally for a long time and I honestly haven't had to replace very many 4Runner or Taco front end parts. LBA's once in a while, OTRE's here and there and rarely UBJ's and ITRE's. I haven't had a lot of problems with Moog or NAPA premium stuff, but don't know how any of it holds up to real wheeling as I live 55 miles from Boston and southern Maine is ruined for offroading.
You bought a new 555 lower ball joint that was similar to what you took out? Can you take a picture? The 555 is often rebranded by Napa, Moog, and others. But it clearly was an inferior design with a greasable fitting and a metal on metal design. You could tell it was metal on metal because it doesn't have the same smooth movement as the OEM design which is a polished ball in a teflon liner.
alexaturner
