I just put in a new 22re motor and want to protect it. New water pump, new t stat, and the radiator which seemed to work fine on the old motor is about 2-3 yrs old. Th truck is not overheating, but I did notice the other day that the lower hose was cooler than the top, while at warm operating temp. I could grab the lower hose and it was luke warm. Is this indicative of a failing or clogged radiator? Or does it just mean that it is doing it's job cooling the water before it goes back into the motor?
Also, if I need to swap out the radiator, it seems pretty simple. I have a manual tranny so there is no oil cooler attached or anything similar right? Just drain it, remove the shroud, detach the top and bottom hose, remove mounting bolts and lift out right?
