Made a boo-boo when trying to do the DRL disable.....
Focoty
So I've been meaning to disable my DRL's for a while now and since I knew it was a matter of a wire snip and I had a couple extra minutes this morning I decided to do it. So I pulled out what I THOUGHT was the correct harness above the gas pedal, saw the black wire with hello stripe, cut it, and taped it off. Well the lights were still on of course. I was in a hurry so I didn't have time to deal with it right then. I'm having a heck of a time thing to find proper wiring diagrams but what I think I might have cut was the ignition #2 wire in the ignition harness? Could that be? Runs and drives just as it did before hand. I do have some wiring connectors that I can try and fit on there if I did something really bad. Does anybody have any idea what wire in particular that is? I'm not able to get a picture of the specific he was right now but I can try later this afternoon. It's directly above and behind the gas pedal and is a smaller one.
You didn't do your homework. If you cut wire #2 that is the wire to cut for pre 2001 4runners. For 01-02 4runners you need to cut wire #12 that is black with a yellow stripe.
I knew I needed to cut the black wire with yellow stripe and that's what I did. BUT, it was in the harness directly next to the one where I was supposed to cut it. That's where the mistake was made
wwarren702
