5 years ownership – maintenance done 2003-2008
:bounce:
I am going to include maintenance and costs in this thread because I want readers to get an idea of the maintenance that is expected for these vehicles. Yes, a 4Runner engine can run for 300k but expect to spend $500+ a year fixing things. For most of the time I have owned the truck, I have had other people work on it. I have done some small things myself such as starter and eventually the suspension but for the most part I had to take it somewhere. Part of the reason for this is because I was in the Navy and had no garage and limited knowledge of auto mechanics.
Rough estimate on miles, some of it is from my log, the rest is from memory
100,000 miles ------- Warranty replacement of factory coils
110,000 miles ------- Spark plugs, change diff fluids
110,000 miles ------- $350, Timing Belt and water pump [done at Naval Exchange, used non-Toyota parts
120,000 miles ------- $650, Re-build rear axel seals and redo rear brakes (ruined by axel seal fluid) at dealer
130,000 miles ------- $350, Valve cover gasket and belts
135,000 miles ------- $280, Replace front brake pads and machine rotors @ Midas
135,000 miles ------- $280, Rear axel seals go again
, dealers fault, they agree to redo for parts only
138,000 miles ------- $100, Re-surface rear drums and adjust brakes; this time I go to The Truck Shop in San Diego
I decided to switch mechanics at this point. No more stealership, no more Midas. I started going to a local shop “The Truck Shop” in San Diego. Reason: you can talk to the owner; they know what they are doing; good prices & honest.
139,000 miles ------- New spark plug set
July 2008 ------------ Fuel filter replaced
Aug. 2008 ----------- New exhaust: Flowmaster with tundra resonance silencer
Aug. 2008 ----------- $400, Lower Ball Joints replaced (luckily they started to ruin my tires => detected the failure)
Summer 2008 ------ $350, Steering Bushings, replaced with poly ones
Summer 2008 ------ $550, Install rebuilt steering rack => like new again
Sept. 2008 ---------- $550, Complete front brake rebuild – upgraded front brakes to Brembo slotted & cross drilled rotors with performance pads. Installed via The Truck Shop in SD. I still have factory limited calipers but this setup is awesome, my truck stops so hard the tires will shred.
Sept. 2008 ---------- $150, Tranny Pan drain plug starts to leak; spot weld repair, this is much cheaper than a new pan.
Cracked Head CYL #3
Post 771701 -->
http://www.toyota-4runner.org/3rd-g...al-build-maintenance-thread-2.html#post771701
