The other day my maintenance light came on. The manual says it only comes on when oil cahnge is need. I just changed my oil 2k ago. 10w-30 synthetic. How do i reset the light or is something else in need of maintenance
I think the T4R takes 5W-30.
The T4R will take anything. It's upto the owner/user what he/she puts in. :guitar3:
Turn on ignition (not start), set the mileage indicator to ODO
Turn ignition off.
Hold reset button for the trip indicator down, and hold it.
While holding button, turn ignition back to on (not start)
Watch indicator light, it will blink several times, then release button and turn off ignition.
You should be good to go.
Good Luck
because that is what the manual says.I've done it without the first two steps. Why do you need those?
Despite the rumors, the OM will NOT burst into spontaneous combustion if exposed to light.
also if you look at your oil fill cap, it clearly states 5-30.
even a monkey could figure that one out on the oil.
