I have a 99 2.7 4cyl. I could not believe the truck did not come with a maintenance schedule. I bought a Haynes manual but some the suggested maintenance seems rather extreme and unnecessary. 3 areas of concern are:
1) Automatic Transmission, I've always had manual so auto's are somewhat of a mystery to me. How/what do I need to do to keep it running? I've read about dropping the pan and changing a filter? Is this necessary if things are working fine? I would think I'd be ok just changing fluid ever 60-100K miles and only "dropping the pan" when it starts to shift funny.
2) Engine coolant. I've never seen RED engine coolant. What is this stuff? I had to do a double take to make sure I actually had the coolant. Manual is worthless just says use Toyota approved coolant. Can I just use the standard green stuff or extended life yellow coolant? Or is there something specific that I have to use this fancy red stuff that I've never seen before.
3) Engine valves? I read the Haynes manual and it said to check/adjust the valve clearances every 30K! WTF? I thought this was a modern vehicle. The only other vehicle I've ever had to adjust valves on was my 1968 VW beetle. Is this a mistake in the Haynes manual? How necessary is it to do this? The truck has 100K miles on it and I'm fairly certain this has never been done and certainly not something I want to DIY.
Thanks in advance for any help.
