TRD04RUNNER said:At 15k you should:
change your air and a/c filter
lube the drive shift and slip joint ,
rotate your tires and check you PSI.( you should rotate ever time you change your oil at 5k)
and check all your fluids.brake,PS, etc
noting really major till you hit 30k..
91bulldog said:where can i buy a toyota A/c filter?
